‘15 AR192 flush - no water out the side??
osuart
NA
I’ve done the flush after every use and 2x had water come out the starboard side holes and 3-4x no water out the side..... normal? Ive read the manual and this one page is burned in my brain but doesn't‘s help my “what if” scenario....
Normal when flushing on a hose depends on house water pressure. If I use my salt away canister I dont get water out the side outlet. If I go straight garden hose I usually do get flow.
Depends on your water pressure from the city. Low pressure won't make it to the relief ports.
Also if you boat in freshwater lakes, you don't have to flush after every outing.
Great to hear - @yjander and @Gunner we will only be on freshwater. We just moved south and built a home that has lackluster water pressure - so it sounds like that’s my issue. Thanks!!
