BlynSqryl
- Other
- 242 Limited S E-Series
I’ve read several threads but still need help. Lanyard switch has been checked. If removed it kills the switches and will not allow either motor to be started. Same situation for clean out switches. SB motor sounds sluggish turning over but it does turnover but won’t start. Port has no issue starting. When throttle is in neutral it allows me to start. When not in nuetral it won’t even turn over as expected. My fear is when I left it at the marina overnight I’m not sure what happened afterwards because it ran fine when I dropped it off. What items should I check next?
