BubbaMechanic
Hello everyone...
I have a 2004 AR230 Jet Boat with one of the engines that has compression issues. It all started with engine running rough then eventually found fuel in the oil and fuel / oil mix in the intake box. And you all know that is probably from a bad ECU or stuck injector. I pulled and cleaned and checked all the injectors and they seem to be working fine. Long story short, because i was concerned about engine damage and thin oil, I pulled the motor out and did a compression test on it. The first two cylinders came up to 140psi and the last two came up to 180psi. My questions are:
1 - What should the compression be in these engines?
2 - What does that difference in compression indicate? Blown head gasket? Dirty or leaking valves? or piston rings not sealing / ie damaged cylinder walls from thinned oil?
3 - Any ideas on what I should look for / do next?
I already did an oil change (there was no existing oil I could suck out of the tank at the time - could have been because I didn't have the boat level at the time) and threw the oil filter away so I can't really go back and see if there were shavings in the oil filter. Now that I have the engine out I could find the crankcase drain plug and drain the oil there, or I could drop the pan entirely.
I have heard a ton of negativity about a SBT core replacement combination crankcase / valve head assembly - if that is where i am headed due to the compression issues. So wondering what the thought is there.
Learning a lot...so bear with me and any comments, answers, or advice on the above questions are appreciated.
Thanks!
Thanks!
