euro_e30
- Hampstead, NC
Port engine starts and runs great on land , when we dropped it in the water today it would start idle for 2-3 sec with rpm jumping and then die, if I gave it throttle and held it about 1,500 it ran just fine. On top of this it seems like there is not much thrust power , both motors ran great 2-3 weeks ago with lots of power after new ecu install , slowly it seemed like I would losing speed / power , not when I have it at 7-8k at start up it seems like in cavitating a lot, could a pump issue be causing the bad idle when in the water or is this totally separate ?
Few possible things I would thinking something stuck inside the jet pump ? I did remove the jet pumps from the boat and found a fishing line wrapped around the shaft I was able to spin it freely but did not dissemble it to see if anything was going on inside, we have also only been seeing 35-40mph at best maybe so I think pumps need to be rebuilt on top of all of this
Any help would be appreciate
