YamahaCC
- MA
- SR
The other week the Starboard engine would not turn over, I adjusted the throttle/shift and it fired right up. Years of ownership and never had this happen. It was in N but figured it was a fluke. However, the last two times I have been out it has required me running the throttle back and forth through N for it to turn over and start. It is fine all day with countless starting with no issues but when it sits for a week it will 'act up'. I am assuming it is a faulty neutral safety switch starting to go out (typically they fail and do not go out gradually though). It is not a battery issue nor an issue with the switches under the hatch. Before I have my tech replace the part I was curious if there was anything else with these boats I am missing that could also cause this to happen? Thanks!
