JayW24
- Memphis, TN
- SX
While I was on the lake but idling yesterday, I turned the wheel and thought I felt a couple pops. But once I throttled up, the boat seemed to drive and steer normal. Once I got into the no wake I still didn't notice anything until I dropped off my wife at the dock. When I tried turning around, the boat just wanted to keep turning in a circle and wasn't reacting to my steering inputs. I then turned off the engines and went back to see that port side jet was not pointed in the right direction and I could reach down and move it with my hand.
I took the boat out of the water and it isn't something that I can see broke out back by the nozzles. Do you think I could have broke a cable? And is it ok to use for the rest of the weekend if I point that nozzle straight? It seemed to drive normal when applying throttle, just at no wake, I had to use no wake mode only on the starboard side and leave the port side in normal idle.
