100% mechanical. I'll add that in almost 9 seasons I've had to replace a motor and the gps antenna. To my recollection that's about $450 worth of maintenance. Hopefully you are getting good components.
Knock on wood my display is still good. The part that sucks is that it started taking forever to get GPS lock and the PP guys said there was a battery in the GPS puck that ran down. I want to say it was $200 or more. They offered no discount or anything....just part of normal maintenance. Seems like bad design.
Yes, it is a bit counter-intuitive. The 210s from those MYs have APS modules (accelerator position sensor?) - so you can install RideSteady system there, but the 230s (with HO engines) - don't...
