14SX190
- South Florida
- SX
I am open to suggestions on what to do next to find reason for "OH" alarm which kills power. At first it would go off once then fine rest of day. Happened again and again same thing a few outings. This past outing four times I had to stop. I checked obvious things every time during wash down at home. No alarm on hose.
I did not have heat gun with me for temperature check but EM did not sizzle spit (Old days of Nitro RC) but pee tale was on warm to hot but not scalding.
This started after new oil cooler was installed. Otherwise it is flawless in performance. Boat runs fine at 47mph despite new metallic noise I hear outside of the water like impeller hitting housing. Going to also remove pump next. I was trying to avoid it as there is no loss of thrust but now I have that noise.
Things I have done:
1. All cooling lines blown through with no restrictions
2. Jet pump screen clear
3. I have tested thermostat with boiling water and it pops open. Going to run with out and see if it stops.
4. Removed Thermo Sensor under cylinder #1 Intake Manifold. Still has dielectric grease inside rubber boot. Sensor appears intact. I am willing to send Thermo Sensor to someone who can use Multimeter and interpret service manual procedure to test it.
5. Removed hose from EM nipple and had significant water flow while on hose.
I am hoping to reach a member that has knowledge to test it or member who has sensor and willing to ship it to me to diagnose a bad one before ponying up money on a sensor and not be problem.
Already tried FS section to guy from a year ago and no luck....
Weather is not good in Miami so I don't mind problem solving if I can.
Things I have done:
