Yes it was doing it when before changing plugs. Still has same issue after change but a few minutes later it went back to running fine. Know it’s back running rough and won’t rev past 6000rpm.
We swapped fuel pump lines from one fuel pump to the other. Same engine ran rough. It has warranty but that is 7 hrs away and we are on vacation at lake.
