ZGhost
- Minneapolis, MN
- 242X E-Series
Definitely won’t forget when I did this service? ?
- $150 Yamaha kit from Yamaha on Amazon
- Trailer and boat level on the driveway.
- 4 qrts out from each engine, yes 4. Looks like the dealer had it full to upper mark on each engine.
- Refilled with 3.5 qrts each engine. Oil level after refill is mid point between two marks before cranking the engine and just above the lower mark after cranking. Of course will check again once on the water.
- checked batt connections, hoses, clamps, and fittings and all look good. Looked around the engine bay and plugs area.
To squeeze or not to squeeze a few pumps in the shaft bearing is the Q? I know, it’s debatable at 10 hrs but don’t have grease at the moment so no squeeze today anyway but maybe later. I need to buy some marine grease. Does Yamaha have their own marine grease brand? Searched for it but nothing came up?
