Markk
- Grand Prairie 75054
- Limited S
Started my audio upgrade today. Amp board was first on the list. I can fit and sit in the helm, but man that is a tight squeeze.
I needed a board that was 3/4"x14.5"x30" and was too impatient to order one from Amazon so I built out of PVC boards from Lowes. I glued the seam with PVC glue and set in an aluminum channel at top and bottom. Turned out very rigid.
I liked how others had mounted in the helm, but I didn't want to cutoff service access to speedo wiring area or the side gunnel area that leads to the throttle area. With some help from my son, we designed a board on hinges that can swing out of the way. It will also make access to rear of board for dressing cable much easier.
I was able to hang hinged side from existing helm mounting points that already had heavy backing block. Other side is supported by aluminum u-channel that I put across helm opening.
A couple early photos below. I'll post some more as it progresses.
