Hi All,
I'm in the market for a used boat and find myself being drawn to the 190/195 series Yamahas, primarily for their cost and ease of towing/storage. I'm looking at 2016+ models because I like the articulating keel and cruise assist/no wake modes.
I am worried however that the single motor under powers the boat. I'll wont being doing many top speed passes but I do want to be able to tow for watersports and get on plane easily.
So 19ft owners do you find that you have enough power or are you wishing you went w/ a dual motor model?
Thanks for your thoughts!
What kind of sports do you do? Our 2017 AR190 does everything but Surf well right out of the box. It just doesn't have the weight currently many (included
@haknslash ) have made acceptable setups for surfing with a little work though. Wakeboarding and Wakeskating is perfectly fine, and plenty easy. Hardest part is speed control (we don't have RideSteady......yet), but once you get that down, it's really not bad.
A 195 will have TONS of power for watersports. A 190 will have adequate power for watersports. The 195 will drink premium, the 190 will sip regular fuel. 195 will have a higher top speed (around 50-ish), and the 190 will top out around 40-42 or so. Both have the same hull, and articulating keel design. The 195 has a larger 160mm pump as opposed to the 155mm on the 190, this results in a bit more thrust, and a little less cavitation in general. Think of less cavitation as better "traction" with the water.
I have had 7 100+lb people in the boat with 2 full coolers, and pulled an 8th up on a deep water start on a wakeskate. He LEARNED how to ride the skate that day and had never been up before. The only mods I have are ribbon delete, sealed intake tunnel, and L13 Cone. Getting rid of cavitation is the single largest hurdle to cross in making the 190 a decent tow boat, the second is speed control. L13 fixes the first RideSteady fixes the second. Overall the 190 is a fine boat if you're a casual watersports person. I will skate at least once an outing, and will get maybe 5-6 pulls at a session. I'll often take others in our group of friends out to skate as well, and we always have a good time, and power is never an issue. We'll always run out of drinks, time, fuel, or energy. Keep in mind I'm 6'2" tall and 225lbs, and I'm coming out of the water on a skate that is about 70% of the surface area of a wakeboard.
Wakeboarding is even easier since the board is so much dang larger. Surfing even easier than that. Those boards are so large, with so much surface area they pop right up. I've done dual ski's behind my 190, and I've come up on two and dropped one (I don't have the talent for a slalom deep water start, it's not a power issue). My biggest issue with riding the skate behind the 190 is any "pitching" of the boat results in varied line tension between the boat and the rider. This is just the nature of a tall tower on a short boat. The aspect ratio of of length to height isn't great, and results in this small issue.
Tubing is another story though. I've not been overly pleased with the towing performance of the jet drive. It bleeds a ton of speed in the turns, and has required a significant rethink on my technique from our I/O boat we used to have. The power is there, but the traction is not in the corners. I've been told that fins will help with this, but it hasn't been a big enough issue for us that I've invested in them yet. This is season #4 on this boat, so we'll see if that holds again this year.....With that said, there is plenty of power to get up on plane with multiple people in a large tube. The rear tow eye is plenty strong, and you can get a medium sized payload (100-150lbs) outside the wake pretty easy. There is some splash to the face of the riders from the jet wash, however a slightly longer rope (we run 75') mostly eliminates that.
The 190 has a few other advantages over the bigger boats. Tow vehicle doesn't have to be as large, it fits in a standard 7ft garage door (with some simple mods), and it's cheap to own and operate. Our 190 has proven VERY reliable over it's 122hrs of service so far, it's been fairly inexpensive to operate, and overall been a great boat for our family of 4 (mom,dad, 8yr old boy, 2yr old boy). There is TONS of storage to take "all the things" with you, plenty of power for watersports, nice rear platform for lounging, and we've towed it all over the place relatively easily, We intend to keep it for at least a few more seasons before upgrading.
