Trousertrout
- Scarab
- 215 ID
Hello everyone glad I found this forum, it has already been very helpful! What I found out is that the Lake of the Ozarks in Missouri on Memorial Day weekend is not a good place for jet boats. They raise the water to the proper level about a week before the holiday, this stirs up lots of loose sticks, moss, trash, you name it into the lake. On 3 separate occasions I had a stick get sucked up into one of the pumps and cause it to slip. I’m so glad I got the 215 because I was able to shut both engines off and figure out which one had the debris in it and keep it off just running the other engine at half speed to make it back to the dock. We have a lift so I was able to get it out of the water and get under it and see the stick. I made a tool out of a piece of rebar with a 90 degree bend on the end and was able to hook the stick each time and get it out. Other than that the boat ran awesome, it has the wake3 setup and I can’t wait to surf behind this thing! Hopefully next weekend the debris has made it’s way to the dam.
