Kaschool
- Portland OR
HI All - soon to be proud owner of new AR210 . I was thinking about adding a dual battery setup but then I thought that perhaps a simpler solution would be a good quality solar panel. My primary use case would be cruising around a little on the boat but often stopping and having music playing and at some point I'll be upgrading speakers and adding amp. Could be out on the water on sunny days for 6-7 hours.
Does anyone have any thoughts or even experience with adding solar to be able to play stereo without draining battery down, and getting away with this on a single battery setup? if so where did you mount the panels, how is your setup working, which panels did you use etc?
Many thanks for any input
Rich
Rich
