tim2808
- Spring Hill, TN
1. Dead battery. This is the start of our third season with our 2013 AR192 and I always have the battery on a trickle charge. Bumped the engine in the driveway, all good. Got to the water and nothing. Volt meter in the speedo said 8v. Soooo, went and bought a Walmart battery to get out on water quickly and its all working fine now. My question is, does the YES warranty cover the battery? I'm gonna call the dealer and see what they will do for me. Just curious if anyone knows.
2. The valve that you connect the hose to inside the boat to run the engine is leaking. Like when I am at 6-7k rpms water will run out of that connector and down the wall. It's a pretty steady stream too. Not like a flood or anything but it shouldn't be doing it. Anyone had any issues with that valve going bad or anything?
The boat has 78 hours now and I guess I have exceeding some computer limited breakin period cause the motor will run up to 7,800 rpm's now. Before 7,200 was the max. That was a surprise for me today when we were screaming across the lake! She's running awesome and, after the battery situation, everything was perfect all day.
