jacoviii
- Independence Mo
- 255XD
I have 2 amps for sale they are oem HTX6 one out of my '18 242x and one new out of a 2020 212x.
I can add RCAs to the oem style plug in male or female it needs only 1 set of L&R RCAs to run the 4 high channels and the 2ch or bridged to 1ch sub channel. I can also add to the oem outputs if needed. at cost of parts (cheap)
Or I can send the clips you crimp on and you could do it yourself.
I wanted to run 2 of these in my 242x but I'm adding more subs (4) and it will be simpler if I do a dedicated sub amp and a new Highs amp.
I will flash the DSP on the amp to make sure L/R are in order. Yamaha wired some of the boats with the inputs flipped but rather then fix the wiring they just reprogrammed the amp.
