Neutron
- New Bern, NC
Usually when you have that many codes and some are not pertaining to your engine, i would think ecu related but its very rare.
Can you monitor all the sensors and parameters with your scan software?
Does everything show up and work?
If so then i would think the ecu is working properly if some or most are not working then i would lean again to a ecu
On my scan tool, i can do some active tests like injector on/off, fuel pump, etc. And can see the sensors as well as things like lanyard switch and many other things that wont throw codes
