2019 SX210 Connext Failed, RPM gauges and Wake mode not working as well...
tob1y2k7
NY/NJ
Hello All,
We purchased 2019 SX210 back in Aug 2020 with 30 hours and its been great cruising and fishing.
When I was doing an oil change in Spring, I notice that the connext is not turning on, RPM gauges not working and wake mode as well, I've checked all the fuses and they're all good by the battery and even checked by the air filter.
Everything else on the boat is working fine and my warranty expired back in March...it happens all the time with my luck...:mad:
I've searched all and some has same problem but then it was fixed with the warranties so no other information abut what was fix and cause it...
1. Can someone help me if I missed anything out or forgot to check?
1. Can I just buy the connext would it work again? or do I need to update the software or calibrate?
I see that the price of connext is around $700.
Thank you so much for in advance.
John,
