2023 sx190 trailer brakes
ryanotown22
I wanted to possibly replace my rotor and pads on my trailer, the passenger side rotor has a single grove around the rotor and it squeals at low speeds from that side. Any idea the parts I need or cost for dealer to do it?
Sounds like there is a piece of something stuck in one of the pads? Are you boating in fresh or salt water?
How deep is the groove?
I just made a thread on bearing and disc brake maintenance;
That might help with the disassembly and reassembly process. You’ll need a 7mm / 9/32” Allen drive to get the slider pins out which will allow you to remove the caliper. You’ll need to high temp silicone grease to lube the slide pins with.
Also take a small pry bar and push the caliper over a little bit to ease removal.
While you’re at it service the other side as well.
