2025 Best Modification Award (if not the best all time mod) goes to TeenGee
FSH 210 Sport
Tranquility Base
I meant to post this before the new year.
I’ve been on this site for five years, just a Padawan but still learning, I’ve seen some really great modifications with instructions for the average do it yourself make my boat better person. And what I’m proposing does not take away anything from how great I think those idea’s are, @drewkaree ‘s anchor locker drain modification comes to mind right away. The quest for the dry bilge is something most strive for.
@TeeNGee ‘s contribution of figuring out how to add an O ring of the proper size to the late model clean out plugs to tighten up the fit and eliminate any water coming in from there has to be one of the simplest and greatest idea’s on our jet boats. He even went so far as to post up a PDF of all the various O rings of the correct diameter and different cross sections to adjust the fit if the one he posted was too tight.
The added O rings effectively eliminates any water getting into the bilge from the clean out plugs because there is either no water getting into the tubes or so little that it is inconsequential. So many people have posted in the past how their hulls take minutes to drain bilge water after pulling the drain after a day on the water. Secondly it seals off any air that could get pulled past poorly sealing clean out seals that could contribute to cavitation. Combine the @drewkaree anchor locker drain fix with the @TeeNGee clean out plug O ring mod and most boats will have a dry bilge. An elegant solution to say the least, no more slathering on toilet bowl gasket wax that works temporarily but leaves a long lasting mess.
Just brilliant!
Well done!
Begins at post #90
@Spooky pantz may still have some for sale
Just brilliant!
Well done!
Begins at post #90
Thank you.
