As mentioned, these engines are built to run WOT all day long. They're the same engines used in Waverunners and when was the last time you saw those putting around? One of my favourite things to do is cruise along at 25mph and shout "hold on" then punch it - she rockets off to 45mph in seconds and slams your passengers back in their seats as they grab the "holy s#!t" handles and yell out obscenities. Good times!How hard can you run the 1.8 HO engine.
Whatever I feel like really. The only limiting factor is the bimini deployment which is rated for 45mph. If we're cruising or floating, it's open. But if we're going to do some running, then it gets folded up on the tower and we let her rip.What cruise RPM do you use?
Awesome. I like how the boat feels at 6000 RPM and higher. I want the engines to last, but still have fun. Seems like the 222S has a little more drag than the 212. 6000 rpm gets me around 34 mph. Engines have 10 hrs on them now. I don't think it's getting full throttle. With the throttles all the way forward the wheel on the manual throttle to electric throttle converter still has a quarter inch to go before it hits the stops. I'll get that adjusted on the 10 hr service. Tops out at 47 mph so far.
yep ok at 6K but 7-8K on the MR1s seems to be the happy spot...With an tr-1 or 1.8l engine.
MR1 more like 8k. ( I know there are fewer of us every year, but still going)
The best thing you can do to make the engines last is to use a high quality motor oil / filters and change it often. There’s plenty of what oil to use threads to read, I’m hoping this will not turn into another discussion on that here.
As far as adjusting the stops on the throttle lever go…while it is important to have full throw on the throttle lever, keep in mind it is a variable resistor / potentiometer that does have some variability into it. That being said, there is a “maximum” output so to speak that commands the ECV to open fully and this may happen before it hits the stops, there’s a procedure in the service manual where where the ohm readings and output of the throttle is checked and set.
What you are really after is to make sure the engines are reaching the rated rpm’s, which I believe is 7400-7500 on the 1.8L engines. There are a lot of factors that can affect top speed through the water, wind / water conditions, total weight in the boat, hull cleanliness etc.
It has been my experience that simply adjusting the cable to the stops made the two throttle handles be out of synch with each other while keeping the engine rpm’s in synch at various throttle openings. My advice would be to put the throttles in the wide open position (with the boat off!) and measure the gap on each throttle lever and write it down, that way after you adjust the cables if you find that the cables need to be put back to how they were you can do that easily.
Thanks for the info. I'm getting 7200 RPM max. With the port engine getting 100+ more rpm. I was just going to use Yamalube 10W-40 4W.
You are right there rpm wise… what elevation are you at? Are you in Salt or Fresh water.
That oil is a fine choice, keep it clean.
487 ft and Fresh water.
At that elevation I think you should be hitting 7400 in hot weather, 7500 in cool weather.487 ft and Fresh water.
