222S Design Issue with rear cup holders
TracyR
222S
Hi - been trying to diagnose what is causing my new 222S to bilge (no kids, no water sports - yet) a LOT. Turns out that the rear cup holders empty into the lower compartment, they are not routed to a line that empties outside the boat. Took weeks for my dealer to figure this out. Don’t know if this is a design flaw or a bad build. Used black marine caulk to plug cup holder holes. No more water. Heads up.
Any one else find this issue?
Unreal.... does the boat have lil drains off the back corners? My 255xd has one on each side that the cup holders go into and then out the boat. I found my hoses not attached lol, but there. Otherwise they would drain directly into boat.
The boat does have drains off the back corner. They are tied to the 2nd row of cup holders - the ones that don’t get backwash each time you slow down. Interesting way to build the boat. I don’t see any drain lines in the far back of the boat. I’m going to contact Yamaha and see if this is truly a design flaw or if they forgot something. I don’t really expect an answer.
Fwiw,
The two forward most cup holders in the bow, two on the transom, and six of the eight rod holders in the cap rails didn’t have overboard drains attached to them, they drained into the bilge, two of the six rod holders drained into the two aft port / starboard storage compartments. I plugged the drains in the bow cup holders, bought some universal rod holder drains for those that didn’t have drains then tied everything together with 1/4” pvc tubing and tied them into the two deck drains I added.
