Jtmains
- 195S
Hey team, desperately needed some help. New to the Yamaha 195S (2023). Purchased used with 6 hrs. love the boat. Been on boats most of life and familiar with jet drive (own 97’ gtx - grandfather pass down) somewhat.
Had been out on the water most of the day and was heading back on Ohio river (gross I know but super close) running full throttle at 47/48 mph, smooth water for no more then 5 miles. Almost back and both check engine and overheat warning came on screen.
Immediately slowed down and placed in center position “neutral”. Opened engine cover, and everything felt and seemed normal. All 3 pissers were flowing continuously and same as always.
Tried moving forward, only got be limited, makes sense. Shut everything down.
Check everything you can quickly do on the water, absolutely 0 debris.
Started up after few minutes, came back on so limped to the ramp and was able to trailer. After I looked everywhere, even with the help of service manual, no luck.
Finally gave up took to dealership 1.5hrs away. They said, they see the code and tested with 0 issues.
Got it home, ran for 1 minute, no water and came on in 45 seconds.
What am I missing here?
