242X E Shorlandr wiring replacement
Bigplanet
242X E-Series
Wiring got shredded as it comes out the front of the trailer. Anyone know what replacement wiring will fit this trailer?
You could just buy a universal 5 pin trailer harness and splice it in. I got rid of the flat five and wired in a heavy duty 7 pin round so i dont need an adapter anymore
It is basic wiring - anything will work. Pretty easy fix.
The wiring harness has a 3 way plug just after it goes to the Y split off on the rails. Mine was destroyed by salt water and the triple plug was not available anywhere cut that off and just run new wiring from that point forward very simple.
Simple enough. Thanks for the replies! Really like the idea of just splicing in a 7 pin... no more losing those adapters!
