dalcini
- Utica, Michigan
- 242X E-Series
I would appreciate any comments advice on my LTS (long-term storage) checklist below.
I also have questions that I couldn't find definitive answers for:
QUESTIONS:
:: Edited
QUESTIONS:
- I've seen some discussion questioning whether removing the air box is necessary to fog the 1.8HO engine. Do some people just disconnect the breather hose and fog through that port? (thanks to @Leojay for the excellent videos by the way)
- It looks like most recommend changing the oil before storage - would it not be better to give the motors fresh oil in spring before running? Or is the idea to get the impurities out of the engine before it sits in the off-season? (Answer: Yes - confirmed by @Cambo)
- What (if anything) do I need to do to prepare my ballast bags and ballast system for freezing temps? Antifreeze flush?
- Has anyone ever removed the OEM SIDE ballast bags from a 242X? The center bag was easy to remove, so I'll probably keep that in my garage - but I have no idea how one might get the side bags out (for maintenance/repair/cleaning, etc.)
- Add 50oz (1oz per gallon) of Fuel Med RX to tank (or Marine Sta-Bil stabilizer)
- Fill tank to mix it in. (this introduces Sta-Bil into the engines during fogging in later step. Many use stabilizer all year)
- Check and clean bilge area and pump strainer
- Engine oil (M.M. Pg 3-14)
- Lay cardboard or plastic in boat to protect floor from messy stuff
- Run engine on hose - 5 mins
- Drain oil
- Remove old filter and pour into extractor with the rest for measurement
- Lube rim and install new oil Filter - torque to 13.3 ft-lb (18 Nm, 1.8 kgf-m) (M.M. Pg 3-15)
- Replace new oil - same qty as removed
- Engine Fogging:
- Prepare by connecting water to flush port but don't turn it on
- Start Engine then immediately start water
- Spray fogging oil into intake for in bursts (to avoid stalling) for 4 minutes (1 min/cylinder per T.E. WCA2011-003)
- Stop Water, half throttle blip 3 secs then stop. (NOTE: If you have a helper, spray during throttle blip & shutdown to avoid burning off the spray)
- Pull plugs & fog for 5 secs in each hole
- Pull kill cord, towel on head & crank for 1/2 seconds
- Put copper anti-seize on spark plugs
- Replace plugs & torque to 18.4 ft-lb. (242XE M.M. Pg 5-1)
- Spray exterior of engines with Yamalube Silicone Protectant & Lubricant, or equivalent. For areas requiring heavy protection, use Yamashield™. (242XE O.M. Pg 180)
- Open fuel tank hatch
- Drain & replace plug if necessary
- Check for issues, clean up, & close
- Drain or antifreeze ballast system (individual preference)
- Remove rear platform clean-out maintenance hatch
- Inspect for trash left from manufacturing (first time only)
- Inspect clean-out area for broken hose clamps (manhole tubes, hoses, etc.)
- Replace and re-seal hatch with silicone.
- Grease steering & reverse cables (242XE O.M. Pg 182)
- Lube clean-out covers with silicon spray or beeswax
- Put clean-out plugs in upside down.
- Remove and store at home:
- Batteries (store in garage on tender)
- Tower speakers (store at home)
- Removable seats/cushions
- All gear (lifevests, etc)
- Bimini top
- Mooring cover
- Grease trailer bearings
- Spray all exposed trailer metal with silicone protectant (bolts, leaf springs, etc)
- Place/Hang Damp-Rid in cockpit & storage compartments (hanging and/or bucket versions)
- Prop compartments and hatches open with corks/white foam
- Release Gate Shift Servos
- Fold Hitch, Wrap & Padlock safety chains around tongue.
- Plug open holes with sponges:
- Engine cooling indicators (pissers)
- Bilge outlet
- Hull Drain plug
- Place coupler lock on coupler
- Store hitch folding pin in tow-vehicle
- Place wheel boot on trailer tire
- Shrink wrap: No zippers, Over tower and down past water line (Protects against UV fading)
- Put trailer up on blocks to remove weight from tires
- Spray trailer leaf springs & all bolts with rust inhibitor
- Visit boat once a month to move rudder & shift buckets
:: Edited
