Anyone having issues with the bilge coming in while just floating? I am familiar with the anchor locker flange issue (been there done that with my old AR210) with Yamaha’s. That’s not the cause.
Mine has been coming on when moored lately. Not previously a problem. I'm thinking I have debris in the drain plug thread letting some water in the hull.
I remember seeing a post a while back where someone had the #10 issue around the swim deck. They pulled back the rub rail and there were massive gaps along the sealer/adhesive between the deck and hull. I get some of the fit and finish issues making it through, but that just seems huge.
Issue resolved. Yamaha tech at my dealer isolated the leak at the shifter cable. Yamaha did not properly seal it when built. Had tech check entire boat using The Ultimate Leak Finder thread info. No more leaks! Thanks everyone!
