blamphere
- 252SE
We have been loving the boat so far. No significant factory defects thus far, a few minor annoyances but nothing big. Boat has been great! Painless oil changes at the 10 hour mark with intuitive maintenance reminder reset.
Three issues I need to deal with:
1. Anchor Locker drain - I am either going to replace it or plug it. Definitely taking on water here from time to time. drain does not extend into the locker at all. Bilge pump is not running excessively in my opinion, but more than it should given the conditions we have been in.
2. Anchor locker latch - Need to shim out the bracket that the latch catches. Boat flexes just right to let it pop open
3. While it has only happened once, I assume it was the cleanout latch kill switch - Came down from a 3 foot swell and both engines shut off. Returned throttles to neutral and they both started right back up. I also had this happen once while idling and stepped down off that level to the swim platform. I haven't yet had time to look into it, but I assume the switch is threaded so I can just move it up a little to ensure steady closed contact?
Other than these little nags, the boat has exceeded our expectations!
