3 pissers + bilge on the new 195....
Gonrcng
Florida
AR192
Hmmmm did they upgrade the IC ???
Yes, complete SVHO motor from the waverunners. Besides being larger, the SVHO intercooler has two outputs compared to the single SHO. I am curious if the 195 engine will also heat soak, and what the real final speed will be.
Also mated to the larger 160 mm pump which will make better use of the extra hp.
@Julian - Didn't you have a speed (54mph) for the 195?
I didn't get a GPS speed on the 195.....the post on the 195 has the speed from Yamaha at just under 55mph.
https://jetboaters.net/threads/the-brand-new-2017-yamaha-ar195-and-sx195.11062/
Yes the Intercooler is larger....
TheSVHO engine comes with;
  • A larger intercooler increasing cooling efficiency by 25%
  • A larger super chamber
  • Larger injectors to increase fuel flow
  • A new, stronger forged piston design
  • A new oil cooler increasing cooling efficiency by 110%
Turbo???
