4.3 Connex Screen Cal
R0B6
New member here ?
Does anybody know the procedure for recalibrating the Connex touchscreen on a 210 FSH as it does not have physical buttons?
I believe in the depths of the menu there is a factory maintenance/technician menu. Most likely in there, though if you are that far out of calibration you might have trouble accessing. In my profession when an industrial HMI (touchscreen) goes bad, sometimes it helps to use a stylus. More precise than your finger.
I looked through the service manual and didnt see it there either.
Thanks for the input. I did find this info from an earlier post with an AR240:
"Hold the system control button down for 5 seconds, will enter a hidden screen, scroll to touch screen with joystick, you will have 2 options. Reset screen to factory settings (I tried this and it didn't rectify prob) other options is recalibrate screen. I pushed this and it put X on screen to push (it recommend stylus I used finger) do this for every corner. ."
Just wondering how to do this with a touchscreen only interface (no joystick) when the touchscreen is not working???
work closely with your dealer, I suspect you are still under warranty. Mine was willing to order the part and send to me to install. I just had to return the broken part.
I've reached out to the dealer. They said they have seen this issue in Yamaha boats before. I will need to bring it in so they can verify that it can not be repaired before they will make a claim with Yamaha. Sound like it could take some time... Just trying to avoid that if I can.
Thanks again for the help
The 4.3 in screens do not have a calibration screen. The information from an earlier post that you found is for the older 7 IN screens. The 4.3 in screens do have a diagnostic screen which is accessed by holding the Settings (Gear) button down for 3 seconds on the screen, but for this display there is only a color test to test the display itself. If you do not have touch sensitivity at all, then more than likely the screen has went bad. If your display is delaminating then it probably got moisture in it that shorted the screen.
