400+ hours on a 2019
calebj06
Would you be afraid of it? Anything special you would look for or address? Seems like a lot of hours, but if you figure 4 full seasons then it’s really only 100 hours a season.
i just want to make sure I service/ address anything that might be needed before it becomes a problem.
A lot of info on the site. Can you provide some answers to the questions below?
Freshwater or saltwater?
Kept on a lift, trailer, or in the water when not in use?
How’s the maintenance from the owner such as regular oil changes, spark plugs, etc?
If saltwater, how’s the pump anodes look?
have you seen it, heard it run?
I have a 2020 running strong with over 400 hours. If the boat looks good and runs good I’d have no concerns.
sorry for the lack of detail.
Freshwater only.
trailered to and from lake. All maintainence done by local dealer.
I have already purchased it.It was too good of a deal to pass up.
just wondering what things I should look for going forward.
boat fires right up and sounds fine.
way to cold to put it in the water though!
How much did you get it for if you don’t mind?
