50 Hour Oil Change Inspection
Can0n11
FSH Deluxe
Just completed the 50 hour oil change on my FSH190. No metal found, cut and inspected oil filter for debris and metal.
Nice! Did you send the oil off for UOA? And or send part of the filter medium for a patch test?
Just a visual, magnetic inspection :). Used to run JOAP/SOAP tests after the first flights way back in the day!
Right on…. Good on you for taking the time to open the filter and having a look.
