wahlspyder
- Indiana
- Other
- Other
- Other
Mercury 95XR. Seems to be pumping fuel fine. If I cover the carbs with my hand, it will start, then i can take my hands away and it runs. Every time it is shut off it needs the "hand" choke. Carb issue? Reed valves? It has the auto enrichener, but no electric choke. The resistance of the auto enrich valve is 26 with my cheap meter (manual specifies 18-20 ohms cold and near infinity hot)
