RedBarron55
- Navarre, FL
- Jetcraft
- Other
I bought a Regal Rush 90 hp. Sport Jet boat the other day, mostly for spare parts for my Hobie Jet Skiff.
I figured that just a few parts would cover the cost.
The engine feels like it has good compression (by turning the engine over by hand) and the wear ring I have already built up with JB Weld.
Now my problem is the urge to fix things!.
My thoughts were originally to use the boat for a test fixture to get the engine tested and running.
Towards this end I have bought a 3 cylinder CDM harness and mounting plate (along with the rest of the engine harness. Also bought three CDM 200 hp. modules. With the investment of $70.00 for the electronics I think that the engine (has the red stator) can be brought up to speed fairly easily.
That leaves me with a boat that is close to running condition and in pretty good condition visually.
So far the remaining problem is this particular boat has a threaded impeller and there is a bent blade tip that needs to be repaired.
I see where some have had Impros repair impellers, but I don't know if they do threaded Sport Jet impellers.
Does anyone have a lead on a threaded impeller P/N 820544?
