Speedling
- Cedar Lake, IN
- SS
Ok, I know I don't have one of those huge dollar builds or something, but here's what I'm doing:
I have a box with two subs, Pioneer 400 watt (peak I believe) under the passenger side seat. I had a nice Clarion marine amp that ended up DOA from a member on the other site.
I have made a very nice board and setup for that amp, so I am looking to replace it within the same size etc.
I have narrowed it down to 3 amps from Amazon, by the fact that they fit in the hole from my custom build, aren't too big power-wise to be too big for the 8 ga. wire I ran (although maybe pushing it, it's only like 3 feet!)
and they are decent brands with decent reputation.
If you have other suggestions, let me know! None of these are marine amps, but it shouldn't be an issue in my case. Another amp will be added later when I can afford a tower and speakers. If you suggest another amp please suggest which one of these is good as well. (prices on amazon, but these sites had better descriptions)
Thanks!
Amp 1 - the cheapest, but the closest to the watt ratings.
MB Quart OA800.4 $121 on Amazon. http://www.sonicelectronix.com/item_67853_MB-Quart-OA800.4.html
Amp 2 - A bit more a $179 Kicker 10ZX650.4 http://www.crutchfield.com/S-oENylic9fe9/p_20610ZX654/Kicker-10ZX650-4.html
Amp 3 - Most expensive, but Class D $189 Rockford Fosgate Prime R600-4D
http://www.crutchfield.com/S-F9dye1...osgate-Prime-R600-4D.html?XVINQ=DST&XVVER=CCC
Thanks guys, I know I'm going a bit cheaper this way without marine amps and such, but if you can find one that's a good name etc. I'll consider obviously. I would prefer amazon as I get a 3% discount on anything there, and I enjoy the return policy/guarantee I get there along with free shipping.
Thanks!
- Max Power Rating:
- 4 ohms: 100 watts x 4 chan.
- 2 ohms: 200 watts x 4 chan.
- Bridged, 4 ohms: 400 watts x 2 chan. - Note: max power rating, so max on subs is 400 as well, good match, or do I need more amp and turn it down?
- 1 X 60 amp fuse btw
- 120 watts RMS x 4 at 4 ohms (160 watts RMS x 4 at 2 ohms)
- 320 watts RMS x 2 in bridged mode (4-ohm stable in bridged mode)
- 2 X 40 amp fuses btw
- 100 watts RMS x 4 at 4 ohms (150 watts RMS x 4 at 2 ohms)
- 300 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
- No built in fuses but recommend 60 amp in line
