Dr_Zao
- Other
- Other
- Other
Hi,
Looking to possibly get an AR192, probably a 2016. A few things stick out that I'd like to clear up from some actual owners. I've owned pretty much everything except a jet boat. PWCs, I/Os, outboards, and inboards. Looking for a general jack-of-all trades 19ft that will fit in my garage. My main reason for looking at jet is the bigger interior for the LOA. Compared to something like a Chaparral 19ft bowrider, the jets are much roomier. I would use it year round on both lakes and ocean (Florida), mostly lakes though.
1) The bench seat thing (passenger seat by the glove box). What's the deal with that? It seems a bit awkward. Where do you sit on it? In what case would you ever fold it? Is it comfortable to sit facing the side of the drivers head?
2) Range. Jet boats burn more fuel that most from what I've read, I'm worried about the overall range and available hours on the water without refueling. Boattest has it burning the entire tank in 1 hour at WOT. We go places that lack gas stations so being able to go for a long time without fueling is important. With typical mixed use (wakeboard a bit, cruise around, stop at a beach and chill)... can it last a half day or day on 1 tank? Some anecdotes would be great since the test numbers don't match typical use.
3) Tower speakers. Seems like none have them stock... is that a reasonably easy and affordable add-on to make?
4) What are the main differences between 2015, 2016, 2017 models?
5) How badly does salt affect the engine? One of the things I like about seadoo vs yamaha PWCs is the internal cooling from seadoo. Is it not really an issue?
6) Maintenance. Would you compare it to other engine types? Less than an I/O?
Thanks so much the any answers!
