@FSH 210 Sport The parasitic losses is an interesting topic/concept. In reality it takes the particular amount of energy to create a particular amount of boost. A supercharger uses crank hp to create the boost, while a turbo uses the otherwise wasted thermal energy from the exhaust stream to produce boost. The losses are LESS with a turbo, but they are not completely negated. The back pressure created between the exhaust valve and the drive turbine are significant, and rob some level of power.
Also, a typical misnomer is that turbo's are top end power and SC's are low end power. The centrifugal supercharger used on Yamaha engines is of the same design as the "cold side" of a turbo. It's a radial flow compressor. The stock supercharger is driven from a gearset off the crank, while a turbo would be driven by a turbine in the exhaust stream........Anywho....Turbos will, in general, move the power band DOWN the rev range, while superchargers will typically move the power UP the rev range. This has to do with the compressor shaft speed, and how in a supercharger it is linked to crankshaft speed by belt or gear, and a turbocharger shaft speed is NOT linked directly to crankshaft speed. So you can generally get a greater shaft speed earlier in the rev range with a turbo as compared to a supercharger.
This DOES NOT include roots/twin screw style blowers. Those are NOT centrifugal devices, but rather positive displacement pumps and work on a completely different set of principles. Those will typically create a "flatter" boost curve, and will deliver boost from just over idle to redline in a VERY linear fashion as (assuming boost is no bled off otherwise) boost is dictated by the ratio of compressor volume to cylinder volume, and rotation rate mismatching.
I've been forced induction/gearhead for decades. I LOVE this stuff. Took a couple classes in college as electives on EFI control theory, engine design fundamentals, and application based prime mover selection. Super fun stuff
