A MUST HAVE FOR ALL BOATERS AND IT'S FREE
Leojay
Jetboaters Commander
WOW, this is something that every boater should have regardless of what equipment they already have on board.
Check out my latest video on this great free app.
The app is free, the subscription to use it is not. I used it last summer as we started boating in new areas and it's decent. I bought a chartplotter to mount in the dash this spring though so don't need the app anymore.
My concern is, would it continue to work in an area where you lose your cell service?
Yes, if you download the maps to your phone with an active subscription. I did that so it doesn't use as much data while boating. Not sure if it will work in a dead-zone though as I think it needs a data connection when you start the app to verify your subscription. It worked well enough, but I found it really kills the battery as the screen is maxed out and you're running GPS 100%, and it's too small on a phone. A tablet might be better if it's bright enough.
With that being said, I believe we're going to invest in a marine gps unit. ThanX
I've been using the Navionics app on the water for more than three years. The auto-routing and "sonar chart" are wonderful for navigating the relatively shallow places I usually boat. I have it set for a 3 ft. "shallow area" - dark blue with dots, and white is 6 ft depth or more.
When in a downloaded map area, it does not require an Internet connection at all. I just put my phone in airplane mode, brought it up and did a new auto-route. Worked exactly as it does when on the net.
At least with my phone, it's kept plugged in to the nearby 12V outlet (with a USB adapter) on the boat and the phone still charges while the app is running. There's also an option in the UI - "easy view" to make the print larger.
No doubt a nice Simrad or other purpose-built chartplotter could do as well or better. However Navionics does everything at least I need, for a very reasonable $15/yr. Map updates are at least once a week, and I've seen small changes in my area after an update.
Navionics was awesome and I used it all last year. The challenge for me was reading it on my phone, it was small for me. I figured I would just add my tablet to the boat, but then the waterproof concerns in a rain is an issue. So I ended going with a Garmin Chart/Plotter for the screen size, 9".
