If you list your address in your profile you may get an offer to try out a boat.Thanks. I was concerned about the wake and wash. Sounds like it will take a little getting used to the wash but we'll be better off without the sharp wake we get from my I/O.
32+ is our speed.
@Avig......as a long time short line competitive slalom skier I would say the wake is certainly slalom skiable and as good or better than a "standard" I/O. You will have no problem at all with acceleration (I sound certain, right) because two 1.8 liter HO Yamaha's will pull you out of your wet suit if the driver is too aggressive. One forum member mentioned tail wag. Yes, that's always a concern. I'm 6'6" and 220 lbs and I could yank most tournament boats around a bit on one handed pulls on a short line. The cure is right at hand. Get a set of Julian's Cobras and you'll be fine - they should place your "tail wag" close to tournament boat performance and waaay better than a "standard" I/O...I'm looking at a Yamaha 242 X E. How does this boat compare to a conventional 22' I/O when pulling a slalom skier?
Dunno about slalom skiing, but in reference to the "tail wag"......I could do that on my old Rinker I/O FAR easier than I can on my Yamaha jet.
If I got way out to the side, layed back and really pulled on the rope to generate some speed coming into the wake, I could easily move the rear of that Rinker around. If I use the ski eye on the Yamaha I can move it "some", but not as much as the old Rinker. If I use the tower, then I get ZERO "tail wag", however the tower creates another interesting problem.
As the boat moves over cross wakes, the pitch of the boat fore/aft changes. This effectively changes the line length on the rope, and leads to an inconsistent pull. In busy waters, I can feel the pull force from the boat vary as it goes over waves/wakes. Smooth water removes this, but we can't always get out on super calm days, and try to get in where we can.
Just some thoughts to add to the discussion.
@DRAT .....not sure what was better the slalom advice or the "other" commentary! ?.....?I've slalomed twice behind my AR240 (I remain the only skier I have witnessed on our lake this summer) and it yanked me up immediately. I am 6'0'-200. The wake is easy to cut and if there was jet wash I didn't notice it when crossing. My biggest problem was that I'm 51 and couldn't go very long (yeah, yeah, that's what SHE said). Also of note, I used the tower tow point and my driver said he could barely tell anyone was back there (I KNOW, I KNOW, that's what SHE said).
I've skied from both the tower and the lower tow point. I'm not good enough on skis to tell the difference to be honest. It will effect where you are in the wake though (as if you had a shorter rope). Coming from the tower as compared to the tow eye, assuming the rope doesn't change, will bring you in closer to the stern. Could be good/bad depending on how the wake shapes up for you.
Yes, I use the tower for slalom and it's great. I think Yamaha actually recommends it only be used for wakeboarding but many posters on this site use the tower for all towables. I know with a higher fulcrum point and a large, aggressive slalom skier you could dream up a safety issue... but our boats weigh 4,000 lbs. I know the ride is great and the driver said I didn't yank the boat around at all. Good enough for me.
Something is wrong. I'd start with a close inspection of your impellers.I have a 2010 Yamaha 242. Love the boat, good power and takes off fast and cruises at 30 to 40 knot pretty easily....However, we were out skiing and the boat struggled to pull me up I am 6.1 190 lbs. and would only get up to 21 knots.
Has anyone else had this issue and found a resolution?
