A tube from cockpit and a device beside battery
Yudi
Does anyone know what this tube works for? Would it cost any leaking I have check inside is wet all times? It seems being cut from previous owner....截圖 2021-12-05 上午12.20.39.png
By the way, What is this device works for?
That’s a drain for the cup holder.
Not sure on the other, maybe some kind of breather vent or something. Just checked manual, I think it’s the canister for your gas tank vent to prevent fumes.
Something looks wrong with that drain. I think one end should go to the cup holder by the steering wheel and the other should run down to the starboard side of the helm area so it can drain into the bilge instead of on your carpet.
Cup holder drain. Standard Yamaha quality crap. I took mine off and got some longer tube and ran it back around the corner. Lowe's, got 50 ft. used it on many of the cupholders that drain right down on the carpet etc.
Yup....cup holder drain, and gas fumes capture canister (CARB compliant)
Yamaha AR 190 doesn’t have cup holder drain tubes. They simply dump into the compartments.
Agreed. No drains on cupholders on the little boats......at least not on my 2017 there were. They all just drained straight to the carpet. I capped all mine, except the rear swim platform ones, where I put a drain in to the rear cleanout tray area.
My 2017 AR190 doesn't have that tube behind the helm.
I don't have a picture, so going off memory here, however I think I have that same tube on the port side behind the glove box, and it attaches to the "drain" in the glove box to empty water out of there (although I'm not certain I've ever had enough water in there to need a drain). I'm pretty certain it's not attached to anything on the other end though, and just drains right into the storage area.
Looks like @Yudi has at least a 2019 boat (Sticker on charcoal canister has 3/19 date on it). The 2019's have a cupholder at the helm (my 2017 does not), so perhaps it's a drain from that cupholder into the storage area to keep condensation off the electrics in the dash? Gonna need a few more pics, or someone else to confirm though.
Yes was going to say his pic looked like glove box and I vaguely remember a drain being there for it. Like you, I just capped or taped mine off so they wouldn’t dump water in the compartments.
