jdbakerucf
- titusville, fl
- FSH Sport
ok, so I am by no means an electrical guru (probably why I'm in this situation), and I'm hoping I can provide enough info that someone might be able to help me out.
So, I have a FSH210, and my accessory switch has become intermittent and I'm not sure why (bot starts and runs fine). When I leave the battery on the trickle charger all night I can come out and turn on the house battery and my switches will work temporarily but as soon as there is too much of a draw on them everything starts to go sideways. For example, I can power up the boat and turn on my Simrad GO9 (it is powered by one of the accessory switches), however while that is powered up if I hit my horn the screen will turn off and the Simrad will restart.
Furthermore, I have trim tabs on the other accessory switch, and when I try to turn those on they will just continually cycle on (like they keep resetting over and over) and it will reset my Simrad as well.
So, it seems like any sort of power draw on any of the accessories is causing them all to go a little crazy, and I'm not sure why. creating too much of a voltage drop maybe?
So, everything was working fine and without issue until I installed an aftermarket amp and speakers. the amp is hooked up to the house battery via a direct 4 awg cable for both the power and ground. the remote wire is coming directly from the stereo, and all of this stuff works fine.
Anyone have any ideas or places for me to start looking? I have tried putting a battery charger on the house battery, I have double/triple checked all of my wiring/connection, and I have checked all of the fuses I can find. I ahve not tried to tear apart the factory wire loom yet to see if there is an issue with the factory wiring, but I'm not sure what else to check. Is there a bus bar or something that all of the accessory wires go to that I can't see? looks like there is a relay tied into the factory harness up by the accessory switches (on the back side of the helm), but I'm not sure if that is for the accessory switch or not.
any help is greatly appreciated.
