4x15mph
- Downingtown, PA
I have added some amps and want to add a second battery now. I have read a number of posts here and it sounds like I will go with a switch that includes an ACR so both batteries can charge. I will also want to add an onboard 2 bank charger.
Can you help prescribe some good options for equipment? I see the following and want to see if I should be considering something else:
1) Switch - https://www.amazon.com/dp/B00BFVHDNA/ref=cm_sw_r_sms_apa_i_QKrOEb4QAQET6
2) 2 Bank on board charger - https://www.amazon.com/ProMariner-4...harger&qid=1589808272&s=sporting-goods&sr=1-4
3) Extension cord for thru hull connect - https://www.amazon.com/NOCO-GCP1-16...30CAB8DTXJD&psc=1&refRID=W725T0KBM30CAB8DTXJD
