Josserman
- 242 Limited S E-Series
Been running off stock batteries, with a 0g power and ground run to helm and 2 amps going to them. Adding a fuse panel up there and will connect that in, with the amps for accessories. I’m planning to buy 2 6v 235’s to provide additional power while anchored with engines off. My thought was to have the amps and fuse panel run to a switch in the battery compartment where I can manually switch between the new set of 6v’s or the house 12v’s. The 6v’s would be charger solely from and inverter at the dock and be used when engine is off. When running I would have the switch set to the house batteries and the system would run as it does now. I would connect the ground from my 6v series setup to the ground of my 12v so there was a common ground.
As far as inverters I would use a 20-30amp inverter for the 6v series and a 10amp inverter for the 12v pair.
Any concerns with this, in my hear it seemed straight forward, but more I think about it I wonder if I’m jut better off with 2 new 12v larger batteries, but why throw out perfectly good working batteries that I currently have. One thing I’m realizing is that I’m ending up spending a lot more on extra inverters with the above setup, perhaps the other options is just add a 3rd 12v.
