WildCatFan54
Jetboaters Commander
- Lexington , Ky.
- 242 Limited S E-Series
My previous boat (16 AR240 ) had a grease fitting visible on top of the bearing housings behind each engine on the rear wall of engine compartment. Other than being VERY hard for an old man to contort his body and attach the grease hose , I knew what needed to be done . My new boat (19 Limited LSE) has what appear to be the same bearings (pics attached) BUT with a tube coming where the fitting nipple was on previous boat up to a bracket attached to rear engine block ? It has what looks like a valve stem cap on top the bracket. Does this simplify the process of adding grease to the bearings ? Sorry for the blurry pics.
