Adding tower speakers- Best Amp to run all 6 speakers + 1 bass?
jameskeller76
Georgetown, TX
Boat: 2016 AR240
Already upgraded stock speakers to Polks.
Just picked up some Kicker tower speakers from a neighbor. Its time to amp things up a bit.
So is there a good amp that can run the kickers, the 4 polks and a sub?
Or do I need to just get two amps?
I would say at least 2 amps to be on the safe side.
Any idea if 4 gauge power wire running to a distribution block sufficient?
I'm considering a 5 channel + a 2 channel, both Polk.
It all depends on wattage you are trying to run. But to be on safe side of things again, I would not run nothing more than 2 Awg to your distribution blocks. Then maybe 4 awg going to your amps. But again it all depends on amp wattage. I personally always do 1/0 awg from the batteries to my distribution blocks so future upgrades can be accommodated for.
Good point. Running 1/0 isn't any more difficult. Thanks for the advice.
No worries.
Yup it all depends on individual budget. If budget on wires not too much off concern, I think bigger is the best route. Now days you can find great deals on ebay on things like that.
This is what I'm thinking, so far...
Looks like you are on the right track. Don't forget to get a relay for remote turn on of everything. Nice safety feature for $7 at most hardware stores.
I have never used a relay for remote turn on. I use the remote wire off of the head unit. I have been doing stereos for years without an issue. Any reason for it?
Good call on the relay, added that to the cart and placed the order.
Here is a Kenwood marine app that seeems to be getting great reviews. Just bought mine for $105 off Amazon. Price has gone up just a bit. Weather permitting (currently raining) hope to install mine today. This is a 4 channel amp and Kenwood has the 1 channel amp for $85 on Amazon.
Here's the link on this Forum.
https://jetboaters.net/threads/these-kenwood-amps-are-a-fantastic-value.13028/page-10#post-235557
Nice amp but I went with the polk because it have the 5th channel for a sub.
It's because I'm going with 2 amps. I've read you can run 2 amps off of 1 remote wire but for 7 bucks why risk it.
I run 3 off of one remote wire. Remote wires are just to tell the unit to turn on. No need for a relay when there is already one built in.
*edit, I did go search this and see it is common practice but if it anit broke.........
Yeah, the wire does send a signal which will get reduced with each device you run it to. Again, for $7-10 bucks and a few minutes of time, why not add it.
