Additional Bilge pump
FSH 210 Sport
Tranquility Base
Another thing I had wanted for some time was additional bilge pump. I had thought about the best place to mount it, next to the oem one would be convenient, but lower in the bilge would be better.
My friend suggested a simple mount that would be easy to put in and easy to remove for service. As it turns out when I tested this set up the two bilge pumps came on at the same time. The mount material is expanded pvc board.
I meant to remove the duck bill back flow preventer but forgot, I’ll be cutting that out before the next outing. The oem bilge pump did not have a back flow preventer and I’m assuming that is so that the outlet hose will drain down without effort.
The piece of foam is there to hold the whole set up upright and centered in the V of the hull. Originally I was going to run the outlet through the lower clean out tray drain, however I could not find a check valve that offered little to no resistance, so I installed faux thru hulls or blanks to block off both sides of the clean out tray drain-red arrow.
I ended up putting another 3/4” thru hull opposite the pilot outlets for the new bilge pumps outlet.
Nice to have a redundant bilge pump and the extra capacity. While I was testing the two bilge pumps with the garden hose and once the pumps came on they were staying ahead of the garden hose.
I just bought some of the series 148 hose myself to change out the swim platform drain fittings to stainless steel. I ended up using 3/4 ID hose and fittings. I will install a check valve as well. I will have to enlarge the holes in the hull about 1/16” or so.
@FSH 210 Sport
What size bilge pump did you use?
I put in an 850, it is the largest that still uses a 3/4” discharge line.
Be sure to remove the duck bill back flow preventer so that it drains down like the oem one does. i forgot to remove mine and ended up with a slug of ice in there.
@FSH 210 Sport Did you add the thru hull to the right side of the pissers because the panel on the front side of the Livewell prevent putting on the Left of the bilge pump outlet?
Im pretty sure that was the reason why, and the fact It’s a difficult place to work in. I’ll take a look today and write back if there is room to put the additional thru hull to the left. Seems to me then and now that it was esthetically pleasing to put it there too.
Thanks, I checked that area this weekend and it looks like putting on the left would be right at that divider panel that doesnt want to come out.
I think the only way to get that panel out is to remove the long panel on the inside of the engine bay. That panelhas a long riser that goes up into the gunnel, and that would be a bear to do. I think that’s how you gain full access to the live well.
I did a little clean up today in preparation for mounting a much larger intake strainer for the raw water wash down system which will mount to the starboard engine bay bulkhead.
How the Aux bilge discharge line an oil cooler discharge lines looked when I started today.
Tie wrap / cable tie mounts installed.
Aux bilge line secured.
Engine oil cooler discharge lines secured.
That really opened up a big space to mount the strainer to.
I put extra bilge pump in lower bilge, right at the drain. On the FSH 210 there is a deep vee in between the motors and the drain is in that vee.
There are four bolts in that location. I cut a piece of 1/2 inch treated plywood about 3"x9", drilled a 1" hole in the center for the pump, drilled two 3/8" holes to match bolts already there, and I used wing nuts ( all metric) to attach plywood. I used live well pump because the extra length on bottom part
reached down into vee. I put 3/4" thru-hull drain right above rear pull up handle so it is well above the water line. it only takes about 18" of 3/4" line to attach pump to drain. Pump is as far back as I could get it. I wired it to auxiliary switch on the dash. About 10 ' of wire.
Sounds like a nice install! How far above the bottom of the V is the pick up? Have you tested it? How about some pics?
The pick up is about 1 1/2"- 2" above bottom, it works great, shoots water out back,( I put 800 GPH tsunami pump). I didn't put float switch on it, I kept it manual because factory bilge is still there. I put it for the purpose of getting water out of bilge on the go. When you take off, all water in bilge will go to back and pump will shoot it out thru-hull drain. To make the install easy, I removed the back cover plate, plenty of room to get in there, besides, I had to remove it anyway to fix my leaky live well. While I was in there, I put drain tubes on all the rod holders and cup holders and plumbed them to bottom of bilge to keep water out of battery compartment and engine bay. I will try and send some pictures at a later date.
What you see is a 500 GPH pump in the mock up. I used an 800 GPH pump because the pickup is longer, it goes deeper in the V. the picture of the bottom of the boat shows where the bolts you attach the platform come from.
I did similar in mounting a Rule 800. I applied 3M 5200 to the bottom of a custom stainless bracket. IMG_0421.jpeg
I went with simplicity as far as plumbing goes, 18 inches of hose straight up, out the back.
wiring went straight to fuse block on aux 2, forth from left. Got chart plotter on aux 1.
