ralphsmithiii
- Tampa, FL
I recently picked up a 2015 AR240 and was able to get it out in the water this past weekend to get a feel of it compared to my previous 15ft jetboat. I keep it stored at a local dry storage down the street from my house and wanted to see what the process was to clean a boat this size after being out in the Gulf. It's not too bad except that this time of year it gets dark around 5:30. The storage has a wash station (a hose with free water!) but by the time I got there it was pitch black outside. I still washed the boat down, hit it with some Megs boat soap and mit, flushed the motors and parked her to dry over night. The following day I threw the cover on and all is well.
However,
I'm thinking about adding an aftermarket fresh water system/wash down system to the boat. I've read a few people who've done it here and for the time being I'm thinking about trying this system out:
https://the-spray-box.myshopify.com...items-of-the-week/products/the-spray-box-mini
I believe it'll fit in the rear storage compartment but I'll need to double check. If it does, that's money because its powered by a cigarette lighter adapter, of via cables to the battery but the adapter is right there in the port side storage.
My question/reservation is, does that seem like enough pump to really spray the boat down AND this tank is 5 gallons. I saw a post where someone took this system and adapted it to a bigger tank but I think it was maybe 6 gallons. Is 5 gallons really enough water to wash a boat down inside out? I really have no idea. I think the idea of this system is that the way its designed is to use the pump, hosing and nozzle to maximize pressure and reduce the amount of water being wasted. If I could pull the boat out the water and wash it down in the parking lot that would be awesome. It could then dry and drain mostly on the way home and I'd just have to maybe towel it down, cover it up and park it.
Of course having the shower for rinsing off people, items, etc is also nice but for now I'm trying to find a solution to make cleaning the boat more efficient.
However,
