rkluck
- Powder Springs, GA
- Limited S
Looking for any possible ideas on what may be going on. The air compressor (a Husky) runs and will not turn off. It starts and builds pressure correctly and at around 155 PSI the safety relief valve pops. I have switched the Pressure Switch twice (I thought maybe the first one was bad) and it still doesn't cut off. Both switches match exactly to the original switch even the same number on the switch. I swapped the safety relief valve with another one and it didn't change anything. That told me the that pressure being displayed is correct. I made sure the air tank hole to the switch wasn't blocked (I ran a wires about 2 feet down in the tank. I had it running and pulled the wire off of the Pressure switch and it stopped so I know there is no bypass or short (highly unlikely). One leg of the 120 power goes the switch. The other side goes to the motor. Very simple! This is so simple that I am sure I must be missing something. I am getting another compressor but still want to figure this out. I thought about getting another switch that cuts off at 130 PSI but even if that works, it just isn't right. It is possible that i received two bad pressure switches but thought that would be unlikely although right now that is seems to be the most likely option.
Anyone run across something like this before? Thanks is advance for any thoughts!
