swatski
Jetboaters Fleet Admiral 1*
- North Caldwell, NJ
I have tried various air filter mods in my two yammies. The most recent one - I thought - was the hands down winner:
The good:
The ugly:
I have a lot of soundproofing in the boat already, don't want to take a step back...
...unless the performance gains warrant reevaluation!
I'll use this post to update my testing results.
I will be testing factory boxes vs SS pods under various loads and will swap the boxes with pods on the water, so the conditions should not be a factor which is can be a big issue. Boxes will go back in with and w/o snorkels. I may consider additional cut-outs, like @gmtech16450yz did.
I will be tracking RPM gains/loses and noise (as perceived by my ears).
Well, the boat is in the back yard, ready top roll.
And then... I woke up to this - ARGHHH! - so no testing today...
The good:
- Those are Stainless Steel pods that replace the whole factory boxes
- Perfect fit! (I posted on that somewhere else)
- I have inserted a piece of CC foam between the top of the pod and the bilge bulkhead - sit PERFECT.
- Re-used all OEM connectors, which is even nicer
- And those are also flame arrestors, which is fine - after ribbon delete one technically needs flame arrestors, FWIW
The ugly:
- Well, noise.
