This is a kit to install a tube inflator inside your boat.
In addition to the kit you will need an Airhead High Pressure 12V Air Pump or similar and a 5/8th water hose. I used an Aqua Joe AJPGH50-DWS water hose but believe the Sun Joe® AJPGH50-PRO is the same for less. You also will need a 1 1/4" hole saw and 5/8" to 3/4" hole saw or drill bit.
The kit includes;
1 Air Panel including water proof led illuminated power switch and magnetic closure
5 Hose end fittings one of which is spare
1 Relay housing labeled for battery and pump connections with 5 feet of control cable that plugs into the power switch
2 Tie down mounts for the pump
2 Feet of 3/4" velcro to secure the pump
2 TPU seals for hose end fittings
4 Pieces of shrink tubing for the pump to relay power connections
1 Small tube of E6000
8 [HASH=6194]#6x5[/HASH]/8 stainless steel screws
10 Plugs to seal Airhead fittings (squeeze in with pliers)
1 Plug to seal Airhead pump (glue in)
1 Spare set of suck and blow labels
1 Foot of TPU to secure tube adaptors
2 Velcro cable ties
1 Drill template
Shipping is free to US addresses.
This kit is described in a post at https://jetboaters.net/threads/air-panel-installing-tube-inflator-in-the-engine-compartment.35057/
The kit includes;
2 Velcro cable ties
1 Drill template
