cane.mba
Jetboaters Commander
- Nashville, Tn
- Limited S
So we were out on the lake heading back from dinner at one of the marina restaurants and I got behind a very large (at least 40') yacht. When I went to cross his wake and go around him the boat leapt out of the water, I was a little surprised as we were only going about 30 with 6 adults on board. However once the boat landed I had no thrust, plenty of RPMs. I shut down, and jumped back to check the plugs, thinking I had blown both. However, other than being covered with water both plugs were seated. Worked the throttles back and forth thinking maybe the buckets just got pushed up, started her back up, and she ran fine. Freaked me out for a 1/2 a second, but instead of panicking, I just ran through all the common things I've read about here and we were back up and running in under two-three minutes.
Still not 100% sure of exactly what happened, but I'm thinking maybe I just got enough air into the jets that I needed to shut down for a moment and let the water flow back in.
